Results 1 to 7 of 7
Thread: Pool Temp to website
    May 2015
    Moline, IL
    31
    Was jw if it would be poss. to some how publish my pool temp to my website or anywebsite
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    Re: Pool Temp to website
    when I had a saltwater pool, I had a controller that relayed a bunch of information. one of those was temps.
    Dan
    9,000 gallon in-ground Saltwater pool, plaster, cartridge filer, 1.0 hp pump, Hayward T-15 SWCG, TF-100
    Pool School - Chlorine / CYA Chart; Pool School - Test Kits Compared;
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    I have an AcuRite floating thermometer that I picked up at Home Depot. When I got it home I discovered it can be seen by may AcuRite weather station. That weather station came with a hub that connects back to AcuRite and allows you to either view all your sensors on a private page for you, or publish the information to weather websites like Weather Underground.
    You need the thermometer and the Internet bridge if all you want is pool temp
    AcuLink Internet Bridge: Remote Monitoring Mobile App
    Support the site
    May 2015
    Moline, IL
    31
    i was looking more for publishing something public. Since no company has anything, then maybe something like this Build Your Own Spa or Pool Monitor
    robstar's Avatar
    Apr 2015
    Mountain View, CA
    48
    In this thread, we're trying to decode the data from the AcuRite 00617 -- Automation: intercepting data from Acu-Rite wireless sensors
    ~15kgal IG plaster, hayward cartridge filter, old-ish pool, TF-100 test kit
    pinguy's Avatar
    May 2015
    Pennsylvania
    516
    Quote Originally Posted by brandon1 View Post
    Can you code and solder? A network attached arduino like you linked, along with a sensor (maybe something like Waterproof DS18B20 Digital temperature sensor + extras ID: 381 - $9.95 : Adafruit Industries, Unique fun DIY electronics and kits) could certainly provide a website with a real time temperature feed.
    I don't know of anything off the shelf that does this.
    Helpful Links: Pool Chemistry 101 - Recommended Levels - Recommended Chemicals - FC/CYA Chart - SLAM Instructions - Pool Math
    Test Kits:
    TF-100 - Taylor K2006 - SpeedStir Upgrade - Taylor K-1766 Salt Test
    My Pool:
    28k IG built May 2015 - Autopilot SWG - Pentair VS Pump/DE Filter/Heat Pump
    Isaac-1's Avatar
    SW Louisiana
    6,711
    I did something similar to this 10-15 years ago using a set of cheap Dallas Semi 1 wire serial temperature sensors connected to a computer to monitor temperatures of coolers at a refrigerated warehouse that generated a graph of the past 24 / 48 hours as well as a chart of the previous week and uploaded it by FTP to a web server. Hardware cost not counting the computer was trivial. I think the sensors were less than $5 each
