Thread: Whisperflo 1hp for 13.5k gallon pool
    Apr 2015
    Visalia CA
    30
    Just curious, since I'm new to this, is this pump fine? What are recommendations for best pump v cost?want something that's energy efficient as well.
    Jeff
    30' x 17' plaster pool 13.5k gallons (roughly), The Pool Cleaner (two wheel), Taylor k-2006, Pentair WhisperFlo 1.0hp, Purex triton WhisperFlo .5 hp (no idea why there's two pumps)
    38,271
    Re: Whisperflo 1hp for 13.5k gallon pool
    That is a bigger pump than you need, unless you have high flow rate requirements.
    A 1HP 2 speed Superflo is a better fit assuming you have 230v power available.
    Something wrong with your existing pump?
    Apr 2015
    Visalia CA
    30
    No, just wanted to make sure it's fine. I would like something that's more energy efficient as I'm sure they're out there.
    Jeff
    If you have the typical high California electricity rates your best choice is likely to be one of the smaller variable speed pumps, like the Hayward MaxFlo VS or something similar. This is assuming you don't have a spa, large water feature, or automation system, any one of which would steer things in a different direction.
