Thread: Corrosion or lack thereof on above ground pools
    May 2015
    wadsworth, IL
    9
    I'd like to hear what forum participants think about the risk of corrosion for an above ground pool with aluminum walls, plastic rails and a coated steel frame running a modern low salinity SWG.
    AG, 12 x 24 ft oval, 7700 gal, sand filter
    Orlando, FL
    690
    Re: Corrosion or lack thereof on above ground pools
    Some AGPs have warranties that say no. Personally, I have had them in the past and they worked fine but the salt water is corrosive to certain materials. Even if it didn't void my warranty I would not get one again. I find chlorine from the bottle easier to deal with and when I overfill the pool, I don't have to deal with adding more salt.
    Sharkline Reprieve 15x52 (3/14). Still using Intex 2650 Sand Filter with Hayward Power-Flo Matrix 3/4 HP pump (6/15). Solar Cover cut into strips for easy removal, (2) 2*10 Space Saver solar panels. Swim Jet HD Robot (by Aquabot) (3/15). Chlorine Liquidator (4 gal). 4 person hot tub. Hard pipe is the way to go for improved flow! Retired Lil Shark (3/15). Starite Max E Therm 333k BTU Propane Heater w/ 24 gal tank (7/15).
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,609
    Welcome. Generally speaking, we see very few issues with it. If warranty is a concern for you...check it carefully
