Page 1 of 2 12 LastLast
Results 1 to 20 of 38
Thread: Anyone not doing a pebble finish
    amandahein3's Avatar
    Mar 2015
    rowlett, tx
    853
    I'm seeing a lot of pebble sheen and wet edge pools being done. Anyone doing Quartz? Why or why not?
    Free form pool 90'3" prim, 14180 gallons. TF100 Kit In pool table with travertine top, 3sheer descents, Depth 3.5-5-4, Jandy 2HP pump, Inline Chlorinator, Wetedge Satin Matrix Antigua.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Re: Anyone not doing a pebble finish
    Lots of quartz fans here.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Indeed, WetEdge makes arguably the best Quartz money can buy. They make nice Pebbles, but their Quartz is top shelf in lots of colors. I have CLI Sunstone select in mine. It's excellent too.
    Essential Links:
    Mar 2015
    rowlett, tx
    853
    My pool builder uses this company. Anyone have any reviews or info?
    http://www.amtile.net/plaster/a-m-quartzbrite
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Don't know the brand, but I will say this. If it's a good quality brand, it's all about the skill and dedication of the applicator. It really is about the quality of the install, if you have a good product.
    Essential Links:
    Mar 2015
    rowlett, tx
    853
    Thanks for the input. I've just head how Quartz has discoloration after a few years and that it isn't as good as the pebble finish.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Not true as a general statement at all. Pebbles tend too less than some others because many of those finishes have naturally colored stones in them. A poor install can influence a pebble finish discoloration as well because the base material is still a plaster based substance. If you want the least susceptible finish in terms of discoloring, it would be all tile. Very, very expensive. Quite easily approaching 1/4 the build cost depending on the tile.
    Essential Links:
    Mar 2015
    rowlett, tx
    853
    Quote Originally Posted by Patrick_B View Post
    Ha no way will that be happening. We are set to do just white plaster but I want some color as I feel the white can look dated. I like the smooth finish of the white plaster. Was thinking that a Quartz was a way to get smooth finish and some color. It's also half the price of the wetedge satin matrix.
    I was told by my PB that Wetedge Luna Quartz is being discontinued. Any knowledge on that? I'm gonna call wetedge today and find out directly from them.
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,822
    You can mix Quartz with plain plaster to tint it but do plenty of research first on the mottling that will occur. I happen to love it in ours. The price was right and since I maintain the water correctly I expect to get the maximum possible lifespan out of my plaster.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    mrcarcrazy's Avatar
    Jan 2014
    Odessa, TX
    977
    I have white quartz.... - it's not pure white like traditional marble plaster, but it's close.
    It's superior to old school plaster and way cheaper than pebble. Of course my PB wanted multiple thousands of dollars more to do quartz over traditional plaster. Then luck worked out in my favor and I got it for free.
    IG gunite/plaster pool/spa Started 1/17/14, Plastered 5/16/14
    Size: 12'-21'x39' free form, depth ranging from 4' to 7, attached 6 person spa with spillover.
    Equipment: Whisperflo 2hp pump, Pentair 30" sand filter, Pentair Mastertemp 400k BTU heater, 1hp Whisperflo for waterfalls, and a blower for spa floor
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Ok, interesting.
    That he mentioned discoloring of Quartz. Tinted plaster is by far the most prone to uneven coloration. You can almost count on having at least some with a tint job. I don't know about WetEdge discontinuing Luna Quartz, but they will replace it with another I'm sure. I prefer Quartz as the best alternative. It's smooth, and more durable than plain plaster, much less expensive than pebbles. I would strongly suggest one based on what you've said. There are so many good choices out there. Any color you want. We blended two from CLI to get what we wanted and we love it.
    Quote Originally Posted by mrcarcrazy View Post
    And it gives gorgeous water color! Done again, I'd go closer to this color myself.
    Essential Links:
    Mar 2015
    rowlett, tx
    853
    Will you two post pics of your pools?
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Here's one shot of mine...
    Essential Links:
    SuzfromTexas's Avatar
    Apr 2015
    Houston, Texas
    3,217
    Patrick: Your pool is gorgeous! And I love the color. What were the two colors you blended? Can you see the bottom easily? That's the color I would love - as long as I can see the creepy crawleys..... Thanks for posting the photo. Suz.
    P.S. You must be a wizard with grass. I can grow plants but not grass. Right... it doesn't make sense.
    Suz~Cypress area~ 2015 pool build. 23K gallons. IG swcg system. 35'x18'; 573sf; 104' perim; depth 4'-7'. Bubblers, sheer descents, 7' spa. Jandy: color LEDs; 2HP 2sp pump; 1HP 2sp pump; spa pump; 580 cartridge; 400K BTU; Dolphin M500; PS8; Inline chlorinator not used; Aqua Pure 1400. Blue Granite Sheen. Travertine deck. Lightstreams Peacock Blue TF-100, K-1766, SpeedStir
    mrcarcrazy's Avatar
    Jan 2014
    Odessa, TX
    977
    plaster before water
    after filled. the color changes a lot based on weather....
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Quote Originally Posted by SuzfromTexas View Post
    We did a typical 12 sack mix. CLI Sunstone Select...11 sacks of "Granite" and 1 sack of "Sapphire"
    Thanks so much! We love it and yes, you can make heads or tails of a coin in 9 feet deep. Easy.
    If you want that color, choose a light finish with a touch of grey/tan and a hint of blue. Just a hint. It doesn't take much. Remeber that was one sack of Sapphire that was light blue.
    Essential Links:
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,822
    Color of the pool finish does not change the ability to see the bottom. The water is still clear. The only difference may be that objects in the water may blend in more with a colored background than with a white background. That said, I've never heard of anyone commenting about people being hard to see in their pool.
    Apr 2015
    Houston, Texas
    3,217
    Patrick, Thanks so much! Now if I could just hop on over Midland way! LOL!
    BTW.... when I lived in Ft Stockton, we used to go to movies in Midland. I think we got a 'new' movie in Ft Stockton once every 6 months. Way too many decades ago! Suz.
    Mar 2015
    rowlett, tx
    853
    Beautiful! Is your pool chlorine or salt? You notice any color changing?
    This is such a hard decision to make!! Lol
  20. Back To Top    #20
    Mar 2015
    Forney, TX
    15
    We didn't.
    We went to the Builder's reference list, and emailed / called a few recent customers who did both Pebble_Sheen, or Quartz.
    We both prefer both the feel, and the color of the quartz. Our pool is full sun, from 11:00 am, on out and the color is fantastic.
    I think like anything the cost is a trade-off between longevity vs initial outlay. All things equal, the surface finish of a Pebble "may" tend to be more resilient over the same amount of time as a Plaster. But, The extra $4,000 goes a long way toward a re-plaster in the same interval.
    Just don't go chucking cinder-blocks into either one P
    BD
