Thread: Draining a Gunite Pool
    Mar 2015
    Lebanon, PA
    79
    I want to drain about 10,000 gallons out of my 25,000 Gunite/plaster pool to bring down the CYA levels.
    What is the risk of popping the pool with that amount of drain?
    Located in Lebanon,Pennsylvania.. 25,000 Gallon IG Plaster Pool Installed Fall of 2011...
    Stenner 3GPD pump
    Jandy DEV60 60SqFt DE Filter (Using Puri fiber.)..,1.5Hp Jandy Pump PMPH1.5
    Aqucal SQ 166R Heater...Polaris 9400 Robot/Cleaner
    TF-100 Test Kit
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    Re: Draining a Gunite Pool
    Are you in an area with a high water table? Is your yard soggy for a while after it rains? At the bottom of a hill? Will draining 10k gallons empty out one side of the pool?
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Is that Lebanon PA? Please add that to your profile.
    Very little unless your ground water is exceedingly high. Even then you're talking about less than 50%. It should be fine.
    Essential Links:
