- Feb 13, 2024
- 1
- Plaster
- Pentair Intellichlor IC-40
Hello, we moved into our house 6 weeks ago & we are new to pools. We have a SWG but the previous owner constantly had pucks in the skimmers which I know now from this forum is what likely caused our high CYA (and in turn our non existent chlorine) We have an in ground, plaster pool approx 20,000 - 25,000 gallons.
Our water has been looking great, but 2 days ago it started getting cloudy & now has a slight tinge of green.
Our numbers tested today with Taylor test kit were:
FC 0 literally no color at all to the water sample
CC 0
Ph - 7.6
Alk - 90
CYA - best I can guess with a 3 part dilution is around 285 . When I diluted 1/2 the black dot disappeared still before the 100 mark, so diluted to 3/4 and got to around 95. Maybe I didn't do right?
Realizing even if it’s plus or minus a little for human error it’s obvious, our CYA is extremely high & we must drain/refill but how do we figure out how much to drain?
Also, how does one “drain” the pool? When we backwash (Hayward sand filter) I assume it’s coming from the skimmers, so once we get passed the skimmers, then what? Or is there a way to drain from the bottom of the pool?
Can this be done a little at a time or should it be done all at once? Draining & refilling seems like such a daunting task, but if it has to be done we certainly want to do it right & have it be effective.
Please be kind, we are new & determined to maintain ourselves but seeing as we are only weeks from swim time, we are getting a little nervous we won’t get this right!
Thanks for any insight!
CC 0
Ph - 7.6
Alk - 90
