Thread: Spa leak
    bware's Avatar
    Apr 2015
    The Woodlands, TX
    77
    Spa leak
    My attached spa has begun leaking down to pool level overnight when the pump is off. This happened some years ago my PB replaced what I think was a check valve. Is this what I'm needing?
    Thanks in advance!
    32 x 15 15500 gal. IG gunite, 6 ft. round attached spa, diamond brite 2 plaster, flagstone coping w/concrete spray deck, IntelliChlor IC-40 SWG, 2 hp Max-E-Pro pump, 450 sq.ft. System 3 cartridge filter, 400k Max-E-Therm NG heater, automation is IntelliTouch i7+3, Polaris 280 pressure side cleaner,
    TS 100, Borax
    mrcarcrazy's Avatar
    Jan 2014
    Odessa, TX
    977
    Re: Spa leak
    That is similar to the check valve mine uses. Only way to know is to compare the pic to what you have @ your equipment pad. best to look for branding as well...so you know 100% they match.
    if you drain the spa into the pool, you can pull the valve guts and have a look-see at the seal.
    looking through the site-glass top can you tell that the valve is closed?
    IG gunite/plaster pool/spa Started 1/17/14, Plastered 5/16/14
    Size: 12'-21'x39' free form, depth ranging from 4' to 7, attached 6 person spa with spillover.
    Equipment: Whisperflo 2hp pump, Pentair 30" sand filter, Pentair Mastertemp 400k BTU heater, 1hp Whisperflo for waterfalls, and a blower for spa floor
    bware's Avatar
    Apr 2015
    The Woodlands, TX
    77
    Re: Spa leak
    Quote Originally Posted by mrcarcrazy View Post
    My valve is just above the ground and easy to get to. I shouldn't have to drain the spa to change the valve, huh? Or is there more to this than I see?
    Can't tell for sure that it is closed, but almost certain this was the culprit before.
    Thanks.
    TS 100, Borax
    Re: Spa leak
    I had the same problem and installed a spring check valve on the spa return line. Works great.
