Results 1 to 20 of 20
Thread: Installer suggesting 2 skimmers for 30ft round
    Mar 2015
    Liberty/Tx
    48
    I'm a newbie here. Hello everyone!
    I have an installer saying I really need 2 skimmers and 2 drains on my 30ft round Saltwater 8000. Is this a correct assessment?
    Thanks so much in advance!
    KYle
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Installer suggesting 2 skimmers for 30ft round
    Hey! Welcome to TFP!!
    What kind of pool is this? Above ground? And is that a model...8000?
    Essential Links:
    Welcome to TFP!
    Need, certainly not. If you get a lot of leaves in the pool it can be nice to have two skimmers, but it is hardly essential.
    I wouldn't do a drain for an above ground pool, but would for an in-ground.
    38,251
    Welcome to TFP!!!
    You don't need 2 skimmers, but they may not hurt either. Make sure a skimmer is on the predominantly downwind side of the pool.
    You also do not need a floor drain.
    Mar 2015
    Liberty/Tx
    48
    Thanks so much for the quick replies! It's an above ground. I was reading on here some time ago about the drains and if they were necessary. That's good advice. It comes with an large Hayward skimmer. Also I do not have any trees near the proposed pool location.
    Also, I was wondering how far I could mount my filter/pump combo (1.5 HP) and Hayward saltwater system away from the pool? I wanted to build a nice pad for it behind the garage about 12-15ft away.
    Thanks!
    Oh and also I'm counter sinking the pool 27" below grade
    38,251
    That distance for the equipment is nothing to worry about. You could likely go many times further away before noticing any difference.
    Just use a larger pipe (like 2") for the "long" runs ... in fact use 2" everywhere you can.
    As long as the equipment is below the normal water level, it is fine for it to be 15 feet from the pool. This is a good situation to use rigid PVC, rather than hoses, though that is not essential.
    Mar 2015
    Liberty/Tx
    48
    This is awesome guys thanks...
    Would the top of the cartridge filter need to be below the water line?
    Mar 2015
    Liberty/Tx
    48
    I got to thinking about the equipment below the water line... Wow, looks like I may need to rethink my plans. Are there any scenarios where I could mount the equipment a little above the water line? Any work arounds like a larger pump, etc? With me counter sinking the pool 27" I may find that my equipment is higher than my water line.
    The crucial vertical placement issue is that the entire pump needs to be below the water line. The filter can stick up a bit without problems.
    There are a couple of different kinds of pumps, including ones that need to be below the water line, and ones that don't. However, the kind of pump that can be above the water line is normally designed for much longer pipe runs, and would be outside it's efficient operating range with only 15 feet between the equipment and the pool. There are just a couple of pumps that can be above the water line and also handle the short plumbing runs efficiently. For that you need a self priming medium head pump. For example the Pentair Dyna-Pro and Hayward Power Flo II would both be alright.
    Mar 2015
    Liberty/Tx
    48
    Excellent! Thanks so much for the info
    Jul 2014
    New England - MA
    310
    I guess I never even thought about the height of pool equipment compared to water level? How does that work for an in-ground pool, since all the equipment is likely to be above pool water level?
    2015 Pool Build --> HERE IG 19'x47' w/ 7'x7' in pool spa; 3'6"-8' deep.
    Pentair 520 Filter, IntelliFlow VS XF Pump, IntelliChlor IC60 SWG, IntelliBrite/GloBrite LEDs, IntelliTouch w/Screenlogic2. 400K BTU heater. A&A G4V in-floor cleaning system. WetEdge Prism Matrix Pebble finish. TechoBloc Pavers and Coping.
    Test kits - Taylor K-2006 FAS/DPD, K-1766 Salt, SpeedStir
    38,251
    In-ground pools require a self-priming pump ... the wet ends are designed differently. It can "suck" the air out of the pump (called priming). Most above ground pumps can not do that and required the water to be gravity fed to start.
    Mar 2015
    Liberty/Tx
    48
    Some say the benefits of a drain is being able to clean the silt and trash in the bottom of the pool easier. Would that outweigh the possible problems one may have with leaks or a bulge in the liner floor?
    38,251
    I think it is probably easier to vacuum the dirt out than to get the drain to suck it up.
    Casey's Avatar
    SW PA
    10,423
    When is your install?
    Mar 2015
    Liberty/Tx
    48
    I'm still trying to decide on an installer. I hope soon!!!
    Casey's Avatar
    SW PA
    10,423
    Keep us posted.
    Mar 2015
    Liberty/Tx
    48
    Well it looks like those guys installing the pool bought 1 1/2". I told them I wanted 2". Will 1 1/2" work with two returns with the farthest return being about 40' away? Would I have to upgrade the pump from the 1 1/2 hp?
    Saltwater 8000 30ft round AGP / 22,000 gal / 1Hp Hayward variable speed super pump / Hayward 150sqft cartridge filter / Hayward Aquarite 25k gal salt system / katchakid
  20. Back To Top    #20
    Mar 2015
    Liberty/Tx
    48
    Bought a Hayward sp2602vsp variable speed pump to replace the pump that came with the cartridge filter. Do I need a diverted valve at my filter?
