Thread: Tiger Shark Robot
    Mar 2015
    Rexford/NY
    4
    Tiger Shark Robot
    New pool owner here wondering what the pros/cons are of the Hayward Tiger Shark. Any advice is greatly appreciated.
    18x29x35 (In-Ground) Lagoon Cardinal Steel Pool 25K Gallon
    Hayward Pro Series High Rate Sand Filter Model:S2446
    Hayward Super Pump Model: SP2607X10 1HP
    Hayward Natural Gas Heater Model: H350FDN
    Re: Tiger Shark Robot
    Welcome Peter! I've had a TigerShark for 6 years now. Works great for me with only one issue with the tracks that were replaced in-home under warranty. Was a toss-up on how they got damaged....was probally my fault. Climbs walls great and cleans my 16K pool fully in the full run. Have only replaced the filters once in 6 years with what I would call heavy duty use. Easy to use and clean. Runs on its own power supply that I like. No need for other pumps etc. Does stick on the drain at times...not a big issue. Good luck with your decision!!
    Sami
    16,000 IG, SWG, 175 sq. ft. cartridge, 1.5 hp pump, vinyl, Charlotte NC
    TF-100, Pool School, Pool-Calc
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Hi Peter,
    I dont have any personal experience with the Tiger Shark, but I know they are a good quality robot and enjoy great reviews.
    Divin Dave,
    Oct 2007
    Parkland, FL
    752
    I personally wouldn't buy the tiger shark simply for the reason that its a branded product. You can get the same cleaner less by not buying the brand name. The blue diamond is the best cleaner, you can get one on ebay now for 850 with a damaged box. I would probably buy Dolphin though just for the fact that they are made to be DIY servicable and you can actually get the parts for a reasonable price if you are out of warranty.
    8000 gal diamond brite pool with 650 gal spillover spa, Pentair 3hp VS pump. Jandy Cartridge filter and Jandy Heat Pump. Jandy PDA automation system with 2 Pentair Laminars. SmartPool NC74S Robotic Pool Cleaner.
    mikespoolfl's Avatar
    Mar 2011
    Florida
    179
    I've had mine for over 7 years and still runs great. I have replaced the filters and the rubber tracks. Now that I have leaned the correct levels to keep my chemicals the rubber tracks seem to hold up better.
    Screen enclosed 17K gal 16x30 IG with Diamond Brite finish, elevated 4 jet spa with spill over, Twin dolphin fountain, Hayward Ecostar pump[ Pentair intelliflo VS, Filter Sta rite Posi-Flo PTM 100, Aqua Cal heat pump, Tiger Shark QC robotic cleaner.
    Stenner peristaltic pump model 45MPHP10, 15 gal storage tank. TF 100 with Speed Stir.
