- Sep 30, 2019
- 21
- Plaster
- Pentair Intellichlor IC-40
Hi,
Brand: Hayward
Vac Model: TSQC 2012?
I have an older 2nd hand TigerShark here that has an odd piece of foam on top of the motor unit wedged between the motor unit and the vacuum body and on one side. The engineer in me cannot figure out why it's there and it doesn't show up in the online parts directories. It doesn't appear to be wedged in there, its loose and has some alignment with the motor unit as if there is a protrusion I cannot see that locks it in place. But I cannot push it out without excessive force. I suspect that the motor unit was replaced and whoever installed it forgot to remove the packaging. The unit also collects more dirt on one filter side vs the other. Any ideas?
Thank you,
Patrick
Brand: Hayward
Thank you,
Patrick
