Thread: top job bleach help
    Apr 2014
    California
    97
    top job bleach help
    I found a good deal on top job bleach for 1.50 but can't find % on bottle does anyone know ?
    Central valley, California. Inground pool built 1971, plaster, sand filter, hayward ecostar variable pump, 1.5" lines, roughly 25k gallon
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    top job bleach help
    The MSDS data sheet says it's 6-7 precent. That was last revised in 2005.
    Jeff
    Apr 2014
    California
    97
    Re: top job bleach help
    So is this a good deal?
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    top job bleach help
    Me personally I would go with Walmart's brand. I don't like to use any bleach that doesn't list on the label the precent of chlorine. Plus Walmart has good turnover so you'll get fresh bleach.
    Jeff
    Donldson's Avatar
    NW Ohio
    2,893
    Generally if you can't find a % on the bottle you should pass. I am sure there are exceptions but I have found it to be a good rule of thumb.
    If it is 6%, size, age, and prices in your region decide whether it is a good deal or not.
    From my HTC One via Tapatalk
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Sep 2013
    Dallas-Ft. Worth Metroplex, TX
    810
    14K Freeform Gunite w/60% Blue Quartz plaster, Quad DE filter, Intelliflo VS Pump + Booster for Cleaner, Aquacal Heat Pump
