Thread: Testing ph after slamming
    Jul 2014
    Yucaipa, CA
    46
    I noticed that the ph test may be out of whack when slamming your pool. When can you get a reliable reading? When it is back within the recommended levels or sooner?
    11,400 Gallons, IG Vinyl, Pentair 188592 Quad D.E. Cartridge Style D.E. Pool Filter 60 Square Foot 120 GPM, Pentair 011018 IntelliFlo Variable Speed High Performance Pool Pump 3 Horsepower 230 Volt, 1 Phase Energy Star Certified, replaced liner 8/2011, TF-100 Test Kit.
    ~Kellie
    Jun 2013
    East TN
    309
    Re: Testing ph after slamming
    When your FC level gets to 10ppm or lower then you should get a reliable reading. It could take a few days after your done slamming. It just depends on the water temperature and sunshine.
    18,000 Gallon Aboveground. Sand Filter with 2HP 2 speed Pump.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    I would let the FC drop below 10 to ensure an accurate PH test. At FC levels of 10 and above the PH test can read a false high. 😎
    Jeff
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    The best thing to do is adjust your pH first before SLAM.
    You cannot depend on the pH reading with high FC during the process as it interferes with the pH test.
    Essential Links:
    Jul 2014
    Yucaipa, CA
    46
    Thank you everyone !
    ~Kellie
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    KASCPAMBA:
    You have been given some great advice by some of our finest on the nuances of testing pH.
    BTW, I recognized your user-name and remember helping you get your pool in shape from a very high CYA this past summer. Hopefully all is going well.
