Thread: PH Stability
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    PH Stability
    It's amazing how the PH stabilizes when you don't run the swg, everything running the same except the swg...
    13,000 Gal Pool & Spa
    Jandy Automation /w IAqualink
    Autopilot SWG
    Jandy 2.0 HP VSP, Filter Cartridge
    Taylor (FAS-DPD K-2600, Pool Surface: Plaster
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: PH Stability
    Yes, the SWG aerates a lot with the hydrogen gas bubbles and if you have short pipe runs you may have chlorine gas bubbles that are outgassing before getting fully dissolved. Do you have a short pipe run between the SWG and the first return in your pool? If so, you might consider pointing the return more downwards (next year when you use the SWG again) though that will reduce surface movement to the skimmer.
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    Re: PH Stability
    Would it be better to relocate the swg to just after the jva, or leave it alone?
    The red ball valve is a bubbler, the other to pool, splits at jva to spa water fall, I installed the swg there to replace tablet chlorinator
    Autopilot SWG
    Re: PH Stability
    It is certainly simpler the leave the SWG where it is. In an ideal world you don't want it feeding the bubbler, but in practice that is only a very minor issue. If you have an automation system that knows how to control the SWG, there are some very minor advantages to placing it before the JVA (so it feeds both pool and spa) but there doesn't look to be room there, and again the advantage is very minor.
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    Re: PH Stability
    The water flows to pool and spa from swg, but in spa mode only no chlorination , it would over chlorinate according to AutoPilot. That jva is 3 port which right now its feeding spa & pool.
    Thanks everyone for such great help...
    Autopilot SWG
