We moved into a house with a large inground pool with a vinyl liner last year and converted it to SWG. We were able to keep it balanced pretty easily, except the pH was constantly rising so we had to keep adding liquid muriatic acid. We're ready to open the pool and need some help balancing it before turning on SWG. We just removed the cover and turned on the pump to circulate and run the skimmer to start getting it clean. There is still some dirt on the bottom we need to vacuum, but otherwise it looks pretty good. I would like to know the correct order to balance levels and how to stabilize the pH so it doesn't rise so quickly if possible (what is normal for pH rising is a SW pool?). We got the TF-Pro Salt test kit about late May/early June last year, so the reagents are getting close to a year old. Do I need to buy new ones this year or is it fine to wait until next year? The R-0011L was hard to squeeze out of the bottle, but it might have been like that when new.
I tested the water this morning and here are the results:
TA 70
CH 350
FC 3
PH 7.3
CYA 50
Salt 2600
Temp about 66 degrees
CC I think is 0
CSI -0.62
I need to raise the salt to about 3500. Once I add salt and the pH rises to 7.6 and temp 75 degrees CSI will be -0.3 and 80 degrees the CSI will be -0.25.
My CYA is a bit low. Should I raise it and will that help stabilize pH? Should I lower CH a bit or leave it alone? Am I correct in assuming the pH will rise on its own so I don't need to adjust that, since last year it kept rising constantly?
TA 70
CH 350
FC 3
PH 7.3
CYA 50
Salt 2600
CC I think is 0
CSI -0.62
