Thread: Proline/Goldline Valve Actuator GVA-24 Voltage
    Dec 2008
    Houston, TX
    31
    Can anyone confirm if the Proline valve control runs off of 24 AC or DC voltage? Hayward has said it is DC, but I'm not sure I believe that statement given the other competitor controls are all AC.
    34 x 16 Free Form Gunite - Tropical Breeze Pebbletec, Color Logic LED Lights, ProLine PS-8 control, Goldline Salt Chlorine Generator, 2hp Northstar 2 spd, 1hp Northstar - sheer descent, Hayward 525 Cartridge Filter, Hayward 400K Low Nox Heater
    38,275
    Re: Proline/Goldline Valve Actuator GVA-24 Voltage
    I have always seen the pool actuators (Jandy, Intermatic) listed as 24 VAC ... and since all the actuators are stated as interchangeable, Hayward would have to be as well.
    New Brunswick Canada
    819
    Its 24 V (EDIT) the controller box can be wired 120 or 240
    38,275
    Quote Originally Posted by pooladdict View Post
    Its 24 V and can be wired 120 or 240
    What? I think you may want to edit this.
    24 volts AC.
    Support the site
    Dec 2008
    Houston, TX
    31
    Thanks for the responses. Hayward corrected their prior support email after I questioned its accuracy. 24VAC so it should work with an irrigation valve. I also found a connector and replacement wire for $12 from Jandy.
