Thread: The Pool Calculator - "Tenp" Area
    First Pool Judith's Avatar
    Feb 2014
    Georgetown, Texas
    57
    In the pool calculator there is a area where you put in the temp in fahrenheit. Is that the temp outside or the temp of the water?
    Thanks!
    Judith and Brian D
    16,000 gal; IG Quartscape; Cartridge Jandy CV460 (150 gpm Max); Jandy Pro 2.0 Variable
    Polaris PB460 3/4 booster; Polaris 280 Cleaner; In Line Chlorinator Tri-Chlor (don't use it) Ozonator
    Fill Date 11/11/2013
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    Re: The Pool Calculator - "Tenp" Area
    I have always assumed water temp. Air temp would have no effect on the water chemistry, but water temp does.
    chiefwej
    May 2014
    Current: Singapore Previous: Clayton, Victoria, Australia
    584
    What he said.
    BTW, our current recommendation is to use Pool Math rather than Pool Calc as Pool Calc had been abandoned by its owner until recently.
    Feb 2014
    Georgetown, Texas
    57
    OK, I will use the pool math. Thank you!
    Judith and Brian D
