Thread: 2006 and tf100
    2006 and tf100
    I have the 2006 which I have used for a few years. I was thinking why bring it out if all I need daily is the OTO, Do I really need the 2006 for everyday when the OTO would do just fine. Right? Wrong? Thanks Dave G
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: 2006 and tf100
    Well, the stock answer is can you post a full set of test results....
    But, if your CYA allows you to keep FC below 5ppm (limit of OTO testing) then yes, that can be your daily test along with the pH test.
    I would still run a full set of tests weekly (not including CYA) to make sure nothing else gets too out of hand.
    Support the site
    Killer95Stang's Avatar
    Sunny SoCal
    591
    Re: 2006 and tf100
    Depends on your CYA level... If its within specs.. then using the OTO comparator daily is good... but at least once a week you should probably still DPD test for chlorine level.. and every few weeks go through all the tests. If you CYA is higher than recommended, than the OTO test wouldn't test high enough to give you a value.
    Pool done!! (backyard = work in progress) 32' x 19' inground freeform with 7' spa, baja step w/ (2) bubblers, stonescapes mini pebble finish, rock waterfall feature, 12" raised bond beam, Intelliflo VS, Whisperflo feature pump, (3) 5G Color LED's, FNS + DE 60, 400K Master Temp, Easytouch 8 w/ remote, Intellichlor IC40, Vision Classic Ceramic Kamado smoker, Margaritaville DM1000!!! Party Coming Soon!!
    TF-100 Test Kit w/ Speedstir
    Re: 2006 and tf100
    ok thank you I appreciate the input. Probably just stick with 2006 weekly and oto daily
