Thread: Testing
    Jul 2014
    Portland, OR
    9
    Testing
    Sorry this is a test
    IGP, 20,000 gal., gunite, sand filter sta-rite, ultra flow 1 HP 230v motor, solar heater, floor drain return capped due to broken pipe 2 years ago, skimmer only return, 2 jets in pool.
    44 Y/O IG, gunite, 20,000, Sand Filter STA-Rite 300 lbs sand, 1 HP 230V motor Ultra Flow, Solar Heater 2 years old, chlorinater 2 yrs old, Skimmer only, two ports, drain pipe busted and capped.
    I'm a 53 y/o male with little pool experience.
    Mark
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Testing
    Your test post has been moved to the test forum
    You're done SLAMing when:
