Thread: Can I use a pop up rotating cleaner jet, as a regular return jet?
    Just wondering if I can plug one of these into my wall return jet... This way it would circulate the water better.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    Re: Can I use a pop up rotating cleaner jet, as a regular return jet?
    I keep waiting for some kind of long term review.
    Quote Originally Posted by ryan380golf View Post
    In theory, you could. You would have to glue in a fitting to accept the head and you would have to do it for all returns so the loop is pressurized
    28000 gallon IG pool, 3.5ft - 8ft deep, Stonescapes Tropics Blue Interior, Pentair Intellichlor SWG, Pentair Quad DE 100 filter, Pentair Intelliflo VS-SVRS, Whisperflo 3hp (water features), A&A Max in floor cleaning, Pentair Easytouch 8 Automation, Screenlogic II, Pentair Mastertemp 400k BTU heater, Pentair Intellichem with acid injection via stennar pump, 9'x7' spa with Infiniti edge
    I have the 'circulator', but it will stop rotating from time to time. The smallest speck or grit will jam it. A 'pop up' head seemed to be a good alternative if I could just screw one in...
