- Mar 11, 2015
- 1,760
- Vinyl
- Hayward Aqua Rite (T-15)
We have a toilet that flushes too slowly. A quick search online and some simple diagnostics revealed the siphon jet at the bottom of the bowl and rim jets under the rim are clogged with mineral buildup (the siphon jet at the bottom of the bowl is almost completely blocked!).
I’m in the process of soaking the siphon/jets in full strength CLR as directed in a video I found by a master plumber. After soaking a couple hours I was able to get some chunks out, but there is still quite a bit still partially blocking the siphon jet, so I’ll let it continue to soak.
If CLR proves not up to the task of removing all the mineral buildup, is it safe to use muriatic acid (31% full strength stuff or 14% low fume)? Any suggestions on how to use it? A search online gives mixed results. Some say ok to use, others say no way, it will damage the toilet and is hazardous.
Hopefully, some of our chemistry experts here can offer advice.
Thanks.
Thanks.
