Results 1 to 7 of 7
Thread: Automatic pool cleaner
    Jul 2014
    Hudson Ohio
    142
    Ok still getting a handle on all of this. So our pool "package" came with an automatic cleaner. My question is how often do you run them?
    24'x54" AGP 13,500g AquaLeader Sentinelle | Hayward Voyager CC150 sqft cartridge filter | Hayward 2hp 2spd pump | Hayward Aquaray Cleaner
    38,521
    Re: Automatic pool cleaner
    As often as required to keep the pool clean to your liking ... is that general enough
    What kind of cleaner? (add to your signature)
    Jul 2014
    Hudson Ohio
    142
    Its a Hayward Aquaray
    38,521
    Some people leave them hooked up and running all the time, but it may not run will on low speed of your pump.
    Why such a big 2HP pump? What model?
    jccams's Avatar
    Dexter, MI
    95
    Quote Originally Posted by mrramsey View Post
    I have a pressure side sweep and I run it a couple of hours every other day, sometimes longer or more often depending on conditions. jblizzle's response is really correct, I am OCD so you may not find it not necessary to run it as often as I do.
    24,000 gal vinyl Lazy L, 1 hp pump, DE Filter, Pentair 250K heater, Letro Legend pressure side pool sweep
    Jul 2014
    Hudson Ohio
    142
    That my friend is a good question. Somewhat made the mistake of not researching enough before purchasing. Like most pool stores it seems that they all just want to sell a package deal marketed as good, better, and Best. I usually don't subscribe to that philosophy. The Best package included the 2 speed pump. The model is the Hayward swim pro voyager SW15942STL.
    Mar 2014
    Las Vegas
    288
    My cleaner is running in the pool all the time except when we are swimming. A couple of days without it and the bottom turns brown from all the dust.
    12000 Gallon IG Plaster built 2/15/2014. Jandy 340 sg ft 127 gpm filter, Jandy 1 HP stealth pump. Circupool RJ-45 SWG (overkill). TF-100 with Speed Stir.
