Results 1 to 11 of 11
Thread: Questions on raising PH
    Jul 2014
    Clermont Florida
    56
    My PH is 7.2 and i wanna raise it to 7.5, ive read you should add sodium carbonate, but can i add sodium BIcarbonate, and how much should i add for a 8k gallon pool, was thinking 3ounces
    Re: Questions on raising PH
    Sodium bicarbonate, baking soda, raises TA a lot and PH just a tiny amount. It isn't a very good way to raise PH.
    Both sodium carbonate, also called soda ash, and borax are good ways to raise PH.
    Jul 2014
    Clermont Florida
    56
    Thanks, my TA was kinda low, i added 2 ounces sodium bicarbonate
    Ellington, CT
    262
    Quote Originally Posted by Tristan View Post
    Two ounces? I'm assuming that a typo since 2 oz of baking soda added to 8,000 gallons of water will only raises the TA by 1.1 ppm
    30,000 gal, 20 x 40 ft vinyl, IG, installed 2006
    1 HP WhisperFlo pump, 60 sqft Pentair Quad D.E., Liquidator(8 gallon) with 3/8 upgrade, AquaVac TigerShark cleaning robot
    TFTestkits TF-100 with SpeedStir, WS
    A proud practitioner of TFP since 2013
    Jul 2014
    Clermont Florida
    56
    you sure? my TA is 70 how much sodium bicarbonate do i need to raise to 100
    Ellington, CT
    262
    Well according to PoolMath for a 8,000 gallon pool, to take TA from 70 ppm to 100 ppm you need 56 oz (weight ) of baking soda.
    Jul 2014
    Clermont Florida
    56
    Thank you im not gonna add a ton i added about a pound
    Ellington, CT
    262
    Thank you im not gonna add a ton..
    That's good because a ton will increase your TA by 17,846 ppm where a pound will increase it by 9 ppm. PoolMath
    Jul 2014
    Clermont Florida
    56
    Hahaha, found extra, 2 pounds were added
    Oct 2013
    Chapin, SC
    1,141
    Why'd you ask if you're not going to take the advice!
    Pool size: 24000gal inground Vinyl-Taylor k-2006 and k-1766 test kits and-speed stir
    Intermatic P1353ME digital timer w/freeze sensor
    CircuPool Si-45 SWCG System
    Polaris 280 vacuum/Polaris PB4-60 boost pump
    Pentair IntelliFlo VS 3hp Pump--Pentair sand filter
    Jul 2014
    Clermont Florida
    56
    aye dont worry mate, the 3 pounds added now my TA is 110
