Thread: Step tile question
    Apr 2014
    Florida Keys
    32
    Step tile question
    We have bull nose tile on our steps and on a bench and sun shelf. The guy installing it says this tile won't get grouted because they'll just use the plaster finish to fill in between the tile. Is this common practice?
    Shotcrete IG, 880 sq. ft., 32,000 gallons,, 3.5 - 5.5 deep, SWG, Jandy 140000 Heat Pump, 1 1/2 HP Jandy, 36 sq. ft. DE Jandy filter with an attached spa
    Re: Step tile question
    Yes, using plaster to grout tile is quite common when most of the pool is plaster and there are only relatively small areas of tile.
    Apr 2014
    Florida Keys
    32
    Thanks for responding JasonLion. We have a lot of tile (90 linear feet), and are using River Rok. Does that change things?
    Nov 2013
    Miami, FL
    348
    Hi there! Ours was the same way -- bullnose on all the ledges, benches and steps. They were "grouted" when the pool was plastered. All seems okay although it's only been a week...
    Swimming!: 19x32 IG rectangular pool, 22,500 gallons; 3' - 6.5'; open spa w/ 6 jets; raised wall w/ 1 sheer descent and 2 minijets, 2 color-changing LED pool lights, 1 spa light; Jandy 2 1/2 HP 2 speed Pump, Jandy cartridge filter (320 SQFT), Diamondbrite Cool Blue
    Apr 2014
    Florida Keys
    32
    Thanks that's reassuring. This is what we've got going on:
