Results 1 to 10 of 10
Thread: No pool store!!
    lmnconn's Avatar
    May 2014
    Missouri
    35
    No pool store!!
    Don't mean to brag, or anything; but I have only been to the pool store one time this year!!
    St. Louis, MO, 25000 gal, 16x32 lagoon, vinyl, sand filter, Hayward pump, chlorine, install complete 9/12, Taylor TF100 test kit
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: No pool store!!
    What's a pool store?
    Oh, you meant those places with overpriced misapplied pool goods?
    Casey's Avatar
    SW PA
    10,457
    Re: No pool store!!
    Quote Originally Posted by lmnconn View Post
    Say WHAAAT?!
    I haven't been in one of those thingermabobbers since... well, I can't remember!
    Jun 2014
    Central Florida
    36
    Re: No pool store!!
    Quote Originally Posted by Charlie_R View Post
    I think he means the one's with free water tests that tell you how many hundreds of dollars of their chemicals you need.
    I went to one a couple weeks ago, then I found this site.
    I think I will be buying my chlorine there, but that is it.
    22,000 gallon in ground, gunite, Hayward pump 1.5 hp and 36sq DE filter. Pool installation date unknown, at least 10 years. Screened enclosure.
    Re: No pool store!!
    Actually, my local pool store is the only place I can get cheap bags of calcium chloride, baking soda, and large bags of DH. They actually got me a good deal on my cleaner last year also... which I had to buy at a regular store or not have a warranty. No need for anything else form them though...
    32K gal, gunite, French Gray DB, IntelliFlo VF, IntelliFlo, WhisperFlo, Quad DE 100 filter, IntelliTouch, IC-60 SWG, IntelliChem, Dolphin M5
    Sep 2012
    Gardiner, ME
    165
    Re: No pool store!!
    I bought Cyanuric Acid there this year... Thats it! I can get everything else at Lowes, Walmart or K-Mart ( sams club for bleack. 2.98 a gallon for Clorox 8.25%... gotta buy 3 bottles at a time
    24 ft Sharkline Matrix AG
    Waterway 1HP 2SPD Sand Filter 100lb sand capacity, using 50lb of ZeoSand
    TAYLOR K-2006 test kit.
    Installed Spring 2013
    16x16 Deck Going up Soon.
    Killer95Stang's Avatar
    Sunny SoCal
    592
    Re: No pool store!!
    I get my Muriatic Acid, CYA and occasionally a couple gallons of 12.5% Chlorine at my local independent pool store. All the items at way better prices than the chain store. I've also been known to come home with an inflatable pool toy every other trip, which is about 3-4 times a season!
    I would never say to not go to a pool store, but don't go their blindly, without being able to refute the garbage they sometimes spew. Best example would be like sending my 62 year old mom to Jiffy Lube.... sharks in the water.
    Pool done!! (backyard = work in progress) 32' x 19' inground freeform with 7' spa, baja step w/ (2) bubblers, stonescapes mini pebble finish, rock waterfall feature, 12" raised bond beam, Intelliflo VS, Whisperflo feature pump, (3) 5G Color LED's, FNS + DE 60, 400K Master Temp, Easytouch 8 w/ remote, Intellichlor IC40, Vision Classic Ceramic Kamado smoker, Margaritaville DM1000!!! Party Coming Soon!!
    TF-100 Test Kit w/ Speedstir
    lmnconn's Avatar
    May 2014
    Missouri
    35
    Re: No pool store!!
    Bleach from my local SAMs comes out to $2.66/gal, but my local farm store has liquid shock 10% for $2.00/gal. We are very lucky with prices here in the Midwest
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: No pool store!!
    My 12.5% chlorinating liquid is $3.85/gal (in the San Francisco Bay Area) and even with a 25% off coupon that's still $2.89/gal which is equivalent to $2.31/gal for 10%. So your pricing is indeed quite good.
    Jul 2014
    Peoria, IL
    389
    Re: No pool store!!
    Menards has 12.5% LC for $1.98 a gallon right now. I stocked up, and I have a SWG pool. I use because the aforementioned pool store sold me a chlorine generator that was "just enough". 18,000 gallon pool and a 24,000 gallon generator. Runs at 100% to maintain "normal levels". Use the LC for heavy use times and to keep TC and FC at 5+ for 100 CYA.
    30x20 vinyl IG, Hayward SD60 with Pentair Dynamo 340219 2HP pump, Compupool CPSC24 SWG, Hayward H200FDN heater. APC automatic pool cover.
    Central Illinois
