Results 1 to 7 of 7
Thread: Equipment pad problem???
    Apr 2014
    Florida Keys
    32
    Our equipment pad was poured today and I'm worried. None of the pads I've seen have been done like this photo shows.
    Are all these pipes supposed to be encased in cement like this? I'm confused! Any advice?
    Shotcrete IG, 880 sq. ft., 32,000 gallons,, 3.5 - 5.5 deep, SWG, Jandy 140000 Heat Pump, 1 1/2 HP Jandy, 36 sq. ft. DE Jandy filter with an attached spa
    22,550
    Re: Equipment pad problem???
    I don't really like it to be done that way, but a lot of builders do it like that. You most likely won't ever have a problem, but if you do it means busting up concrete to fix it.
    Apr 2014
    Florida Keys
    32
    Oh Lordy, that would be bad. Well, I guess there's not much I can do about it now except keep my fingers crossed! It does help to know that other pool builders do it that way. Thanks for your comment.
    Jun 2014
    Burlington, Ontario
    59
    My piping comes up through a concrete slab too. Could be a pain if it needs repair but not uncommon IMHO.
    16' wide ~20,000gal IG vinyl lazy L shape pool circa 2002, 1hp Hayward Super Pump, Hayward S244T sand filter, Hayward H250ED2 gas heater, Hayward eVac Pro robot, Stenner pump for chlorine, TF-100 test kit
    2008 Gulf Coast 864 LEi hot tub
    dumbcluck's Avatar
    Aug 2013
    long beach
    674
    It's generally all ran under your decking anyway unless you have paving stones right?
    -Jimbo- My pool was full of dirt and trees. Now it's full of water and children!
    20k gallon inground pool, 18" raised spa 7' round, 8 jets, 3" spa plumbing. Pentair intelliflo 3hp vsp, Easy touch 4 w/ ic 40, CCP 420 cartridge filter, Raypak 407a w/ cupro nickel, Screen logic 2, Pentair intelliph, spa side remote, Pentair 5g color lights pool and spa, TF-100 test kit with speed stir and Dolphin Oasis Z5
    Apr 2014
    Florida Keys
    32
    True true, good point! Guess you're not all that dumbcluck!
    Apr 2013
    Sacramento, CA
    2,769
    My pipes come up thru the poured deck in insulated sleeves.
