Results 1 to 7 of 7
Thread: .95- 96oz Walmart Ultra Bleach
    lulupalooza's Avatar
    Mar 2008
    Evans, GA
    323
    Got me some yesterday! Check and see if your store is selling it!
    *~ Laura ~*
    27x52 Aquasphere Conquest AGP (approx.17,100 gal)
    1 HP Pentair Dynamo Pump & SD-40 Sand Filter
    TF-100 Test Kit
    BBB User- Salt Added
    Crzyfrlss1's Avatar
    Jun 2008
    Central, CT
    161
    Re: .95- 96oz Walmart Ultra Bleach
    I know I'll be out seeing if my local store has it for that price
    I just ran out of bleach and don't want to use the cal-hypo shock bags.
    So I'll buy some bleach anyway even if it does cost a little more.
    Thanks for the heads up
    Intex 15' X 48" metal frame pool
    Waterway Supreme 1hp 2 Speed pump
    Hayward X-Stream 150 Sq. Ft. Cartridge Filter
    2-2'x20' Sungrabber Solar Panels hooked up in parallel on a Goldline GL-235 controller.
    Not getting "Pool Stored" = Priceless!!!
    Thank you TFP
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Quote Originally Posted by Crzyfrlss1
    Where were you getting cal-hypo for less than bleach?
    Edit~
    This is an interesting thread showing cost comparisons....
    cost-comparison-of-chlorine-sources-t1859.html
    ~End Edit
    Crzyfrlss1's Avatar
    Jun 2008
    Central, CT
    161
    Quote Originally Posted by frustratedpoolmom
    Edit~
    ~End Edit
    Wally world...
    5-1 lb. bags cost $11.88 @ my local store.
    Still, I'd rather just use bleach rather instead of adding all that calcium into my pool.
    And bleach is still cheaper, cal-hypo is for when I really can't get the store for bleach
    Edit...
    I usually keep some cal-hypo on hand in case I run out of bleach, I've read the older threads about how some here buy a whole shopping cart of bleach.
    I'm not ready for the strange looks I'll get from doing that
    If my wally world has bleach for .95 I'm filling the a layer in my cart full of bleach though.
    If I don't use it all this season it'll get used for laundry either way.
    Thank you TFP
    Mar 2008
    Evans, GA
    323
    I bought 4 cases tonite of 96oz. walmart ultra bleach. Why is it people look at you like you're nuts???
    *~ Laura ~*
    TF-100 Test Kit
    Crzyfrlss1's Avatar
    Jun 2008
    Central, CT
    161
    Quote Originally Posted by lulupalooza
    If they only knew what it was really being used for
    Anyway, no .95 cent bleach @ my store.
    Thank you TFP
    Jun 2008
    Georgia
    22
    That's funny I came across this thread. This past weekend, I went in to buy the larger 174 oz or something bleach and out of the corner of my eye, I see a little sale sticker sticking out from the shelf below the larger bleach bottles. Lo and behold, $.95 for the 96oz. 15 mins later, I finally deduced that $2.50 for 174oz is a worse deal than $.95 for 96oz. I was ecstatic and decided to load up the cart with 10 bottles. Add that, plus a container of CYA and I was out the door at $20.
    Now, I have 10 bottles of bleach sitting on my garage floor. Good thing they're the smaller ones!
    Doughboy 16' x 24' AGP, 9200g, Hayward 1 1/2 HP pump and Sand Filter. Sparkling water due to BBB method.
    Leisure Time Spa, Salida G-3, 275g. Also clear and clean due to BBB.
