Thread: Add LC
    Add LC
    I have a sport pool which means my returns are at each shallow end.. I am wondering if I should continue adding LC over the returns on the shallow ends or maybe add it directly to the skimmer?
    2003 Marquis Euphoria - 400gal
    Jan 2012
    'burbs of Augusta, Georgia
    7,367
    Re: Add LC
    Pour liquid chlorine in a thin stream over the returns with the pump running and allowing it to get carried into the water for dilution and mixing. I don't *think* you want to subject your pump to a large bolus of acidic chlorine...I don't know for sure but it doesn't sound prudent to me.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,009
    Re: Add LC
    add it in front of the returns.
    high levels chlorine can be corrosive, so putting directly in the skimmer puts high levels into your pump, filter, heater and saltwater generator if you have them and there is no benefit to putting it in there anyhow. Its the large volume of water is where you want the chlorine.
    Divin Dave,
    Re: Add LC
    Sounds good. I suppose brushing after adding it will help.
    Jan 2012
    7,367
    Re: Add LC
    Quote Originally Posted by jjdurrant View Post
    Brushing *always* helps. Everything.
    Got a lot on your mind and feeling stressed?- go brush the pool!
    Missed going to the gym again?- go brush the pool!
    Got a little green schmutz developing in the pool water- test, chlorinate and brush! brush! brush!
    Most of us just don't really *really* brush enough.
