Do you actually use less bleach with the liquidator or is the usage the same? I just pour bleach in front of my jets each night.
jinnbaker1 said:I have been debating about getting one all summer. I just didn't know if it was worth fighting the battle of the white stuff.
What did you change? You used to have WS as you mentioned in this post.cruzmisl said:I use less. It keeps the FC at a stable level rather than fluctuating. I have no WS so far but I keep my pH low (~7.2 to 7.5)
Almost everyone, I presume, has these white stuff floating on the top, but this isn't THE WS. You have WS if your outflow line is no longer transparent because it's full of WS and your flow meter is filled up with milky water instead of clear water.Sabot said:I noticed some snow flakes in the black funnel the other day. Is this the WS which some talk about?
Sabot said:Yes please. Please take pictures of the inside of your tank too.
I have been assuming your "WS" has been in the tank of the LQ and it affects the preformance of your LQ by accumulation of "WS" on the plastic outlet valve and the flow indicator down stream of the LQ.
The "WS" in your tubing is not the "WS" that we have been talking about in the tank. Some believe it's scale and I still believe it's salt. The "WS" in the tubing comes from using the stock vinyl tubing which the chlorine will break down. You will need to replace it with tubing which will handle the chlorine. You can clean out the tubing to a degree with some diluted Muriatic acid or replace it as you see fit with the exact same tubing which you can find at Home Depot. The vinyl tubing is really cheap in price and quality. Just to be sure we are talking about the same "WS" stuff, pictures would aid in the discussion.
Sabot said:Thanks for the pictures!
Wow! That is some serious creame that you have flowing there!
What is interesting to me is that your water in your LQ tank is normal. Deposit seems to start at the outlet and work its way up the valve assembly.
I am not seeing any deposits forming on the feed tube.
You're right. Deposits are ONLY on the "out" line, starting from the "out" float valve and down stream all the way to the pump.
When the water from your tank moves into the outtake, the deposit forms. Do you have any deposit on your intake? (Can you snap a picture of the inlet?)
None whatsoever, as mentioned.
Have you disconnected the hose before the pump and see if the water is cream in color when it comes out the hose? (This can be done when the pump is off and before the drain down)
I didn't need to. There's some limited transparency left in the "out" line. When I squeeze the Tygon tubing I see that the water running through it is a thick suspension of WS. The WS is definitely not limited to the tubing wall.
Why are there deposits on the valve assembly and not on various parts of the feed tube? Does it take circulation to form the deposit on the valve assemble? Why would the deposit not form on the area in the tank that is stagnate such as the tubing or the side walls of the tank? Or even on the float for the valve assembly?
I'll answer to that in the discussion part below
With the vinyl tubing, did the water clarity the same going through the flow indicator?
I had the vinyl tubing for just a week or so. The WS didn't form on the flow meter yet. After I switched to Tygon, it took some time, more than a week, for the WS to accumulate and fill up the FM.
If you disconnect the tubing at the outlet at the LQ tank, does the water flow out of the LQ tank clear or the cream color? If it’s clear, then there is a reaction going on in your tubing.
It would be clear. See discussion below.
I would recommend replacing it to another type of tubing (R3400 Tygon or similar chem. Tubing)
Could you please take a few more pictures of your equipment pad, tubings and zoom out view of the inside of your LQ?
pooltime said:I have been running my LQ since early June and have no WS similar to the pictures above. I do have some crystals on the bottom of the tank which I assume is the salt the manual talks about cleaning out when it is a few inches thick. Wish I had more to add as to why I don't have WS, but I dont...
I have noticed that I get some dirt in the lines from time to time which sometimes clogs the purple float / valve, but a little shot from the compressor cleans it right out.
pooltime said:Hope this helps...
Well water
FC 8.5
CC 0
TC 8.5
pH 7.5
TA 100
CYA 70
