- Jun 7, 2017
- 9,309
- Plaster
- Jandy Aquapure 1400
In my opinion, the connection to the cell should be permanent. This is a very common problem.
Is the arcing between wire socket and pin? If socket and pin arcing is the problem would you not want conductive grease? I though dielectric grease is NOT conductive. Would you not want something like carbon conductive grease between pin and socket?Those pins arc and burn off pins sometimes. I use dielectric grease on the pins and keeps this problem away. The grease keeps a solid continuity which minimizes arcing.
I think dielectric at the base under the o-rings and retainer plate is a good idea but definitely not a good idea on the pin to socket connection. If anything that should be conductive grease.Dielectric also shields the terminals from corrosion.
What brand of dielectric grease do you use?Ever since I've been using it I haven't had not even one scorched or burned off pin. When I wipe the grease they are like brand new. When the cell gets replaced I don't bother with a new cable either as there's almost never a difference old or new connection wise.
