Thread: My newest pool adventure....a critter in the skimmer
    May 2014
    New York, NY
    14
    So there was a dead mouse in the skimmer today. I assumed I should bring FC up to shock level. Did I do right? Is one day enough?
    16,000 gal. rectangle vinyl, DE filter, Haywood 1.5 hp pump, Polaris automatic cleaner, heater, looploc cover. Near NYC. Be the fish
    Mar 2014
    Las Vegas
    288
    Re: My newest pool adventure....a critter in the skimmer
    I would think one day would be enough, but wait for one of the experts to chime in.
    12000 Gallon IG Plaster built 2/15/2014. Jandy 340 sg ft 127 gpm filter, Jandy 1 HP stealth pump. Circupool RJ-45 SWG (overkill). TF-100 with Speed Stir.
    Donldson's Avatar
    NW Ohio
    2,922
    If the body was intact then you don't even need to raise the FC any higher than normal. You can if you want, won't hurt anything, but really no more contaminates than a normal swimmer.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,025
    You should test your water to determine if you need to do anything or not.
    But if it makes you feel better, you can raise the FC for a day or 2.
    Divin Dave,
    May 2014
    New York, NY
    14
    Thanks!
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,429
    As long as the carcass is intact and your FC was within the recommended range you should be fine. Some folks like to bump up to shock level just for peace of mind, but it is not necessary.
    Love TFP? Become a
    TFP Supporter!
