Thread: Hi, I'm Patty
    Hi, I'm Patty
    Hi,
    I am trying to balance the chemistry of my pool - at the lowest possible price - and keep it balanced. I look forward to learning more and working less!
    Patty
    18 x 36 IG, 27,000 gallons, Vinyl Liner, Pump-Purex Triton WhisperFlo 1.0 Horsepowe, Purex Triton Clean & Clear Plus Cartridge Filter, Polaris Watermatic G1000 w/ C310 Controller, Polaris Cleaner, Propane Heater - Built in 2000
    Re: Hi, I'm Patty
    Welcome! You will find lost of great advice to accomplish your goal of an inexpensive, Trouble-Free Pool!!
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: Hi, I'm Patty
    HI, I'm waste
    Welcome to TFP!!
    Please give POOL SCHOOL a good read to find out the basics of what we're all about here and learn how to set up a sig that will help us answer any questions you may have
    Luv& Luk
    -Ted
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Hi, I'm Patty
    Hi Patty and welcome to the forum!
    You're done SLAMing when:
    SeanB's Avatar
    Mar 2007
    Missouri City (suburb of Houston, TX)
    2,622
    Re: Hi, I'm Patty
    Glad you found us - Welcome!
    TFP Founder
    My Pool: 13K gal IG gunite with 7' spa, Pentair Cartridge Filter, Intellichlor IC40 SWG, Polaris 280 Cleaner, TF-100 Test Kit w/ salt test.
    Re: Hi, I'm Patty
    Hi Patty!
    26,000 gal liner IG pool
    Doughboy with concrete construction
    Full sun most of the day
    1.5 hp pump system
    200lb sand filter
