Thread: Used the spa for the first time
    Readyforapool's Avatar
    Sep 2013
    DFW metroplex
    738
    We used the spa for the first time tonight - the water level dropped below the tile line and an hour later it's still not coming up, is that normal?
    Finally Done! - 21x34 IG, SWCG, depth - 3.6 - 4.6 - 6.6, Pentair IntelliFlow 3050 vs+svrs, 60 sq ft Pentair DE Filter, 400k BTU Heater, Polaris 280 w/.75 hp booster pump, Pentair EasyTouch wireless, 38 sq ft raised spa, wet edge Barbados quartz finish - ODK w/36 in Napoleon grill
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    Re: Used the spa for the first time
    The spa is attached, correct?
    Odds are, the bodies displaced water and it spilled into the pool. When you come out of spa mode, it should refill things and have the normal draw from pool and retuirn to spa and pool setup.
    Sep 2013
    DFW metroplex
    738
    Thanks Richard - yes it is attached and no it didn't pull from the pool. I waited over an hour and no rise in water level - so I put the hose in and filled it. This happened once before when they pressure tested for the leak. They changed out the valve and it was fine. Guess I'll add another thing to the list. Argh!
    Normally the water level gets fixed the next time you are in spa spillover mode. That might be most of the time, but typically happens once every 24 hours, so there can be a significant wait, but it shouldn't be more than 24 hours before it fixes it's self.
    If you are in a hurry you can fix it quickly by manually turning on spillover mode.
