Re: DE Filter Cleaning Tutorial
Sure, that will work.
Be careful not to get too much air in the pump. An assistant to add more water to the bucket as you go would help, or place the bucket floating in the pool so you can push it under water as you are finishing up.
That's exactly what I was thinking of doing. I was going to have my husband refill the bucket until all DE is sucked up, then sink the bucket into the pool as to not get air in the line. Thank you. I think I can finally tackle this filter after reading all the info on here. That filter is definitely more intimidating when you have no knowledge of how it works and all the components.
