Your filter now is 24 sq. ft.
In no particular order (other than alphabetical) this is what is available:
If you want to stay with Hayward - Hayward Pro-Grid 60, W3DE6020 with Hayward valve SPR0710XR50.
Pentair EC-188592, 60 sq. ft. Quad DE filter with Pentair valve 261152.
Pentair FNS 180009, 60 sq. ft. DE filter with Pentair valve 261152
Waterway Crystal Water 570-0060-07 60 sq. ft. DE filter with Waterway valve WVD002.
If you have a MPV on your Hayward valve, it should fit the Hayward filter.
You can go smaller, but shouldn't go less than 48 sq. ft. with that monster pump.
Except for the Quad 60, all DE filters have virtually the same performance and, usually, the same grids are used between brands.
The Quad 60 uses DE cartridges. If that is chosen, be careful about the MPV plumbing as the directions are different.
