Results 1 to 13 of 13
Thread: Water drain
    careingemt's Avatar
    Sep 2013
    PA
    143
    Water drain
    Is it really necessary to lower the water level back down to operating level after a heavy rain ... when pool was installed I was told that operating water level is 2nd screw down on skimmer bracket
    AG 18 feet accross 52" high pool wall 7000 gallons .... pool math = 7600
    Hayward extreme cartridge filter 100sq feet
    pool is heated by propane Hayward heater
    pool installed aug 12 2013
    Casey's Avatar
    SW PA
    10,453
    Re: Water drain
    If water goes over top of the skimmer it will not perform it's intended job of *skimming* the top of the pool water.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Water drain
    How high is it now ? The only real problem is the skimmer works better with a lower water level. About half way up the skimmer or so.
    Did your water overflow out of the skimmer with all the rain ?
    Jeff
    careingemt's Avatar
    Sep 2013
    PA
    143
    Re: Water drain
    If I take lid off skimmer water level is at top of skimmer... so I would assume water is coming out of skimmer
    careingemt's Avatar
    Sep 2013
    PA
    143
    Re: Water drain
    Can I drain tommorrow .... rain expected tonight
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Water drain
    When the water level gets high does it overflow out of where the skimmer basket ?
    Jeff
    careingemt's Avatar
    Sep 2013
    PA
    143
    Re: Water drain
    Can I not run pump tommorrow and deal w drain tommorrow
    careingemt's Avatar
    Sep 2013
    PA
    143
    Re: Water drain
    Yes over flows out skimmer hole I would assume never watched to c
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: Water drain
    There should be no issue running the pump, except you won't get any skimmer action at all.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,046
    Re: Water drain
    No pool is perfectly level, so if it overflows, it's going to start at the low side and turn the already low ground into a mudhole, which will cause it to sink even lower, and so on and so on until you have real troubles. I'd lower the level some so the runoff goes where I want it to go.
    Others before you have dealt with it by drilling a hole on the skimmer housing well above the normal full line, but below the rail level. Then it will just drain off through a hose. I looked up an old reply of mine.
    What you want is called a bulkhead fitting or a "through-hull" fitting for a boat. You'll never be able to tap threads in the skimmer, so you need something with some gaskets and a compression nut that you can then attach a hose or a pipe to and run it away from the pool to drain somewhere safe. I'd place it as high as reasonable, so you don't have it draining water when the kids set up waves.
    careingemt's Avatar
    Sep 2013
    PA
    143
    Re: Water drain
    There goes cya I just added
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: Water drain
    You should be ok. Test it and if you need to add some no biggie. 😎
    Jeff
    Casey's Avatar
    SW PA
    10,453
    Re: Water drain
    You're not dumping the whole pool careingemt. You are going to lose some CYA each summer due to rainfall, kids splashing wildly and back washing/maintenance of pump/filter cleaning. That is why monthly testing is recommended.
