Results 1 to 7 of 7
Thread: Tile Cleaning Companies
    Feb 2013
    Pool Country
    138
    Is there any way to avoid using tile cleaning companies to clean calcium carbonate off the water line?
    Perhaps an acid gel of some kind?
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Tile Cleaning Companies
    Acid gel would adhere and might damage the grout.
    Essential Links:
    Feb 2013
    Pool Country
    138
    Even if the acid gel were allowed to only temporarily adhere to the surface (i.e. wiping it off)?
    Mar 2007
    San Rafael, CA USA
    12,082
    Oh, so you're thinking of it as a stripper/smoother of the surface. If that's the approach you are thinking about, I would think that smoothing/buffing the surface (if possible) to have it be glossy/shiny and smooth would be the approach, but it still might not work. Certainly a surface that is rough is more likely to get scale to develop just because of the nature of the surface, but even a smooth surface can have evaporation leave a residue. You'd almost need some sort of teflon-like surface that not only inhibited scale formation but also would have any residue from evaporation "slide off" along with the water -- that is, a very hydrophobic surface.
    Aren't there sprays or liquids one can put onto some materials that make them very hydrophobic -- some sealants that have water bead up after application? Maybe something like that on the tile might work best, but you need to be careful that it doesn't change the appearance of the tile in a way the customer doesn't want.
    Feb 2013
    Pool Country
    138
    Quote Originally Posted by chem geek View Post
    Yes, I remember a tile cleaning company put a very hydrophobic chemical on the tiles that surrounded an elevated island spa. The water flowing down formed a V shape. The pool builder was supposedly furious. Without the chemical, the water would cover the whole tile all the way down.
    Smoothing and buffing will only work for certain surfaces. This will not work for rocks, etc.
    I thought I heard of acid gels that are applied, and take away the solids at the water line when the chemical is wiped away.
    Mar 2007
    San Rafael, CA USA
    12,082
    Yes an acid would help to dissolve calcium carbonate but of course there's a balance in trying not to damage the surface underneath.
    Feb 2013
    Pool Country
    138
    I did some research on the gel products.
    It seems they're much more time consuming than blasting off the calcium carbonate.
