Thread: permanent dye for fiberglass IG pool
    digidutch's Avatar
    Feb 2014
    Tampa Bay area, Florida
    15
    Does anyone know if there is a product you can add to the water to give fiberglass pool a permanent 'color' instead of just white. Would like it to be blueish. Will the dye just be cleaned by Chlorine
    10000 Gallon, Fibretech InGround fiberglass. Sta-Rite Posiflow II cartridge filter. Baracuda G3 suction cleaner in skimmer port. Pump is 1 HP because needed extra power to get H2O up to Solar Roof Panels which we no longer have.
    Re: permanent dye for fiberglass IG pool
    Most of the available dyes only last a day or two, all of them break down eventually. Properly balanced water does tend to be slightly blue, rather than white.
