There is an area on the bottom of my fiberglass pool where the coating has come off. I see tan stuff underneath which I presume is the fiberglass. Is this just a cosmetic issue, or is the pool water going to damage the fiberglass?
Should still be under (10 year) warranty if the gelcoat is failing. Some water testing history could also be helpful. If you haven't done so already, be sure to take part in the survey linked below.
Fellow TFP fiberglass pool owner, TFP is always gathering data in an to increase its extensive knowledge base and analyze that information to provide members with the most accurate and reliable information possible. As such, we developed the following survey in an effort to capture...
Yeah, my pool gelcoat has a limited lifetime warranty, so I should be covered, but they don't pay the cost to refill the pool and re-add all the chemicals
