Thread: Varying info on how much H20 27'x52" holds.
    Mar 2014
    NW suburbs IL
    31
    All pool equipment is based on pool size and amount of water. Can anyone tell me the correct answer for 27' round w 52" walls?
    Mar 2014
    Thomson GA
    166
    Re: Varying info on how much H20 27'x52" holds.
    I have a 17' x 54" and the manual says 17,000 gals.
    Gerry
    27' x 54" AG Salt Water Pool Installed 2014, Hayward 23" Sand Filter, 1 HP 2-Speed Power-Flo Matrix Pump, AQ-TROL SWG, TF-100 Test Kit
    Smykowski's Avatar
    Sep 2011
    3,065
    Volume is going to be based on water height, so you want to use the planned depth of the water, not the height of the walls, if you're plugging into an online calculator.
    bridgman's Avatar
    Mar 2014
    Bowmanville, ON Canada
    461
    If you have 4 feet of water in the pool I get 17130 gallons:
    radius of pool is diameter/2 or 13.5 feet, pi * radius ^^2 * 4 feet deep = 2290 cubic feet, 2290 x 7.48 (# US gallons per cubic foot) = 17130
    Measure the actual water depth in inches and adjust accordingly, eg if 50 inches deep then volume is 17130 * 50 / 48.
    This assumes the inside of the pool is exactly 27 feet... these days companies seem to claim whatever they can get away with so it's probably 25-1/4 feet or something
    Cedar hot tub, 680 US gallons - Snorkel wood-burning heater, canoe paddle, "offline" Intex 1000 GPH pump/filter with skimmer
