Page 1 of 5 1234 ... LastLast
Results 1 to 20 of 85
Thread: New Homeowner / Pool Owner
    Mar 2014
    Orlando
    52
    Good day to everyone, looking for some help!
    I honestly don't know where to start.
    After 3 months of trying to fight a clarity problem which I assumed was from all the dead algae. Which was from shocking a pool which sat for 6 motnhs unattended.... I have tried a floc and vaccum to waste with correct PH , I have tried filter powder , skimmer socks everything in the world. After 3 months I can now see the vaccum head on the shallow end...however the last 2 weeks ive seen no progress running the filter 24/7...now looking more closely at the pool I realized the paint on the steps is starting to bubble and peel a little. Could this be why Im fighting clarity so much , could the pool paint be coming off and diluting the water and therefore is why I cant filter it out or vac it out ?
    Will this result in me having to drain and maybe repaint / resurface the pool ?
    UN1017's Avatar
    May 2012
    Sacramento, CA
    288
    Re: New Homeowner / Pool Owner
    Welcome to TFP!
    Quote Originally Posted by Jimmymcg1 View Post
    You got here so you are starting in the right place. You've stated you have tried a lot of things but you haven't said what your numbers are or what kind of test kit your using. I would start with this thread: http://www.troublefreepool.com/threa...parkling-Oasis. You need to follow the steps explicitly.
    I don't think the paint is your problem. Get us some good numbers and we'll see what we can do.
    15'x30' IG - Roman-style - 14K - Pebble Fina Classico
    Filter: Jandy CL460 Pump: Jandy Stealth SHPF1.5 SWG: Jandy AquaPure 1400 Cleaner: Jandy RayVac Test Kit: TF-100 w/SpeedStir
    Chlorine/CYA Chart----Extended Test Kit Directions----SLAM
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Welcome to TFP !
    If you could post a full set of test results and how you got them that would be great. Sometimes water clarity issues can also be water chemistry issues. These are the test kits we recommend http://www.troublefreepool.com/conte...its-comparison. If don't have one of these gets I recommend that you get yourself one.
    If you could add all your pool and equipment info to your sig it will help us better help you.
    Jeff
    Mar 2014
    Orlando
    52
    Thank you all for the quick replies and sorry about the lack of information ...
    Im embarrassed to say so but for now I wasnt really worrying about the pool chemicals because I figured I'd worry about getting them level once the water was clear and then I would work on making the pool swimmable ....the only thing I tested was the ph and I threw in soda ash when I floc'd the pool
    So I'm looking into getting one of those kits you mentioned , do they only sell them online and if so how can I get you some results in the meantime, just some dipsticks ??
    As far as my setup , I'm not sure how big the pool is if I had to guess I would assume around 14,000 gallons, its a pretty big " Rio " Style pool
    My pump is a 1 hp Hayward , with a 1200c Star Clear Plus with I want to say a PA120 Cartridge Filter
    Also I was getting frustrated not making progress after this long and I turned off pump 2 days ago and let pool settle , today I was able to see leaves on bottom of shallow end , first time since I purchased house.
    Opps one more thing I was rubbing my hands on the wall today and I could watch white dust come off the wall as if it was chalking up...
    -James
    Mar 2014
    Orlando
    52
    quick update , went to look at the pool this morning and its progressively getting better each day that I leave the pump off. Very close to seeing the bottom of the deep end , A Total of 3 days with the pump off....
    Also just browsing through the forums I've noticed that some of had trouble with certain shock brands they use and the calcium filler that is in them.
    During the super shock of the pool I used quite a few cases over a course of 2 weeks , that were an off brand not from the pool store but from home depot... could this be what I'm fighting ? Still working on getting you all some results , would you like some dipstick results or is it not worth it and should I just wait to get an accurate reading
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    No test strip results. Order one of the kits and then post those results. Those will be the results we know will be accurate. 😎
    Yes you could be fighting that super shock.
    Jeff
    Jan 2013
    Houston, TX
    1,079
    Get the TF-100 - only available online but certainly the best option. Odds are any of the other kits that are recommended would need to be ordered online as well, pool stores just don't stock them. Don't take your water to the pool store to get it tested - they are almost always wrong.
    Don't throw anymore puck, powder or solid chlorine in the pool - this is almost certainly exacerbating your issues (betting on a sky high CYA). Wait for the kit, get a full set of results posted here and we will have you up and running in no time flat.
    again - DO NOT TRUST THE POOL STORE.
    TFP Moderator Chris V. ~16K Pool & Spa, 48NSF DE, IG Plaster Circa 2000, Intermatic PE653, Challenger pump with a 2 speed B2984, 20gal stenner chlorine injection, Houston, TX
    One cannot follow Islam and Christianity at the same time, nor can one follow pool store methods and TFP at the same time.
    Pool School -- Pool Math -- TF-Test Kit
    Mar 2014
    Orlando
    52
    woo hoo after going on vacation , starting a new job finally got some spare cash and time to get the TF100
    1st time using the test and tried to follow a youtube video, here are the results ....the only thing is im not sure how big my pool is, if I had to guess I would say its 12k - 14k gallons ...
    Free Chlorine - 1.8 ppm
    Combined - 1.8 ppm
    Total Alkalinity - 110ppm
    Calcium Hardness - 150 ppm
    Ph - 7.4
    CYA - 30 ppm ( I could still see the black dot with the water to the top )
    38,301
    Congrats!!!
    Are you sure the CC was 1.8 and you did not mean total chlorine? Also, use a 10ml sample of water so each drop is 0.5ppm.
    Add some dimensions and pictures of your pool and we can help with the volume estimate.
    First step is to add about 20ppm of CYA and then retest that after a week ... After it dissolves assume that you are around 40ppm until you confirm. You also need to start maintaining higher FC levels and if there is any sign of algae, then you will need to follow the SLAM Process.
    Mar 2014
    Orlando
    52
    Okay I redid the test with a 10ml sample and I got a free chlorine of 2.5 ppm and a CC of .5 ppm, the taylor kit says it test for free and combined so im not sure about total ...
    also here is a picture , im unaware of the depth level in the deep end but I would guess about 6 ft , the length of the pool is ~28ft and the width is ~18 at the widest point
    do I just go to the pool store and ask for CYA ??Sorry Im very new to all of this , thanks again for all the help and quick reply , how many bleach bottles should I put in weekly ?
    [IMG]<a href="http://www.freeimagehosting.net/"><img src="http://i.imgur.com/e0AJsxZ.jpg" alt="Free Image Hosting"></a>[/IMG]
    Jan 2013
    Houston, TX
    1,079
    For CYA - you can go to Lowes, Home Depot, Walmart or the pool store (I would steer clear of te pool store they will try to sell you snake oil).
    It may be labeled as:
    Stabilizer
    CYA
    Cyanuric Acid
    at lowes:
    http://www.lowes.com/pd_86401-1772-0...zer&facetInfo=
    On amazon:
    http://www.amazon.com/Kem-Tek-024-6-...tabilizer+pool
    The amount of bleach is determined by demand - I suggest taking a look at pool school and how to slam again. That will help you get the process down.
    38,301
    I think your estimates of volume are pretty good. I would start at around 12k and keep track of your chemical additions and results. If you are consistently overshooting, then bump the volume up a bit.
    TC = FC + CC ... I was just surprised you reported the CC as the same as the FC in the first set of results.
    Mar 2014
    Orlando
    52
    okay , went and got some stabilizer from home depot and added about 2.5 / 3 pounds to the pool today , so hopefully this will get me up to the 30/40 ppm cya. Do I have to wait a full week to test the cya again ?
    and I'm gonna go ahead and slam the pool , and keep the pump running 24/7
    should I shoot for a 12-14 FC ?? or am i gonna have to wait a week to see what the cya is at and therefore determine how much fc ill need
    38,301
    Wait a week to test the CYA, but assume it is at your target level to determine your required FC levels. SLAM away!!!
    Mar 2014
    Orlando
    52
    okay before work today I went and picked up 5 bottles of bleach and was able to get the fc up to 16ppm which is shock level, im at work for another 5 hours and will test when I get home, I tested the chlorine about 2 hours after I dumped the bleach in and noticed the CC raised from .5 up to 1ppm , so I'm guessing I never was able to fully slam the pool , hopefully this slam will do the trick.
    Also while brushing the pool today , I must have hit some leaves/algae/dirt piles in the deep end that I could never see. It's making the filter psi shoot up rather quickly, within 2 hours it shot up from 14psi to 21psi .....which has me worried to leave it running over night, although the psi was that high the flow of the water back into the pool was still rapid and good but I know you are supposed to keep it running 24/7
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    I would clean, backwash your filter when you get home. While your SLAMing the pool, clean, backwash your filter when the pressure rises 25% above your clean pressure.
    If you could add all your pool and equipment info to your sig that will help us better help you ! 😎
    Jeff
    Mar 2014
    Orlando
    52
    28x18 Rio Style pool ~14,000 , 1 hp Hayward , 1200c Star Clear Plus and a PA120 Cartridge Filter
    Sorry it was up earlier in the thread...also no backwash or drain =/ just hose cleaning it, the plumbing is pool -> pump -> filter - >pool
    I cleaned it twice earlier today and will when I get home
    28x18 Rio Style *painted* pool ~14,000 , 1 hp Hayward , 1200c Star Clear Plus and a PA120 Cartridge Filter
    Mar 2014
    Orlando
    52
    also one more thing, I can only vac to waste with a submersible pump ... and I was having a tough time skimming all the debris out of the pool that I stirred up, most of it is broken up leaves, grass, dirt and some algae
    is this gonna make the slam useless with so much organic matter eating up the bleach ?
    what would one suggest ?
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    I would do your best at getting as much of the debris out as you can. 😎
    Jeff
  20. Back To Top    #20
    30,421
    Are you saying your pool pump is not working?
