Hello,
Easy question. One of the first articles I ever read on TFP was the "Recommended Levels for SWG" and I've been targeting those readings to a tee. When I enter in my readings which are :
FC = 6.0
CC = 0
pH = 7.5
CYA = 70
CH = 300
ALK = 70
In addition, I also select Type of Pool = Plaster, Chlorine Source = SWG and Method, of course = Trouble Free Pool.
Here's my question, it says my target FC on Pool Math should be 5-10 but the article says 3-5. The reason I ask is, I've been trying to dial in my % on the Salt Water Generator so it doesn't produce more than 5.0. However, if 5-10 is the way to go, then I could stop driving myself nuts with adjusting the run time, etc.
The other question, and this might not be worth worrying about but, CSI. I am guessing that the number Pool Math generates for Target Level, I want to stay at or as close to as possible as that Target Number correct?
Thanks everyone for your help!
FC = 6.0
CC = 0
pH = 7.5
CYA = 70
CH = 300
ALK = 70
