Talk about a substandard filter and pump.... I've had so many issues, like not being able to change the filter cartridge because I cut an extra hole in the liner and I needed the second plunger valve to shut the unused hole off....So the return to the pool is just screwed onto the fitting with no valve or ball valve.... I don't have a T junction that will connect the screw on intex hoses so it will make them turn the intakes into one hose, as they don't make them, so I've only got one intake and one return happening... :-( I can't shut the water off for the filter as I need three plunger valves not two, so I have to get hubby to change the filter while I hold a bowl over the return fitting...lol... Just a comedy of errors...
To make matters worse, I think I should have bought the 40mm hose instead of the 38mm as its hard to get it to fit snuggly into the new 40mm pump connections for the new pump, so I might have to buy more hose :-( Any advice anyone???????????????????
Yes we are swimming and the pool is great, but I was hoping to be done by now.... :-( I still have about a fifth of the work to go....
