Thread: Pool buster won't turn on
    Jun 2007
    MA
    165
    My pool buster won't power on any ideas on what I can try? We just used it 2 days ago it worked fine. It's been charging for almost 24hrs and still nothing.
    Cheryl
    14X42 Intex Ultra Frame
    Re: Pool buster won't turn on
    Have you verified that the charger is actually charging?
    Is the battery ok?
    How old is the unit?
    Inground, 2 yrs old, all Jandy gear.
    http://www.laspeedgarage.com
    Aug 2008
    Pensacola, Fl
    58
    Battery died in ours too. We had to order a new Batt and motor kit. Easy to switch out.
    About 23,200 gal vinyl in ground, "stop sign" shaped 22x22, Polaris 3900 cleaner, Hayward Aqua Plus Pro Logic Controller, Hayward T-15 SWG cell, Hayward S244T sand filter.
    Ours died as well.
    Before you order a new battery and motor kit, swing by your local RC store. They use standard size motors/batteries, and you can find cheap replacements for both locally. The whole compartment is pretty easy to get into, just open it up, bring it to the store, and you can probably end up with an even more efficient unit if you want to really soup it up
    Jim
