Thread: Recommendations for Spa Plumbing
    Jan 2014
    SE Louisiana
    147
    Reading up on how many say spa flex is bad for pools/spas. If you don't go with that, what's the best way to make sure you have centered PVC in a 9' round spa?
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Recommendations for Spa Plumbing
    Not sure what you mean by "centered". Do you mean keeping the pipe in the middle of the gunite, or....?
    Jan 2014
    SE Louisiana
    147
    Yes ... in the middle of the gunite. It seems that it would be difficult to use 45's without having the pvc zig-zag and come fairly close to the edge of the gunite wall. Is heating/bending required?
    30,421
    I didn't know spa-flex would be a bad choice. Is it because of the joints?
    mas985's Avatar
    Pleasanton, CA
    11,737
    There have been many people who have had flex eaten through by one critter or another so I would not recommend it for non-accessible areas.
    My spa uses 45s
    Mark
    Nov 2013
    Central Texas
    113
    Depending on city code heat bending a pipe may not be allowed.
    28k gal/raised spa, IG quartzscape, WhistperFlo 2 speed B2984T,DEV60 filter,Lxi400 NG heater, Polaris 280 cleaner, DIY Chlorine injection, Build completion 7/2013
