Thread: Intelliflo Operating Question
    May 2011
    New Smyrna Beach, FL
    16
    When my pump is running in scheduled mode, and I override the schedule by pushing a speed button, is there a way to get back to the schedule without shutting the pump down and restarting?
    8500 gal gunnite pool, built in 2005. Sta-Rite PXC95 Filter, Intelliflo VSP 11018, Heliocol 350 sq. ft. Solar with Goldline GL-235 controller, Heatwave H120 Heat Pump, SwimPure T-3 SWCG.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Intelliflo Operating Question
    Welcome to TFP Paul!
    I'm having one of these installed on my equipment when we build so I can't help much now. I'm interested as I will need to know this, but I think someone should be able to answer this for you.
    Essential Links:
    May 2011
    16
    I called Pentair support today, and posed my question.
    The answer is no!
    Not a real drawback, and, after a week of use, I'm pleased that I replaced my 1.5 HP single speed pump!
    I was concerned about what pump RPM would be needed to draw water up my solar heater, and in my case, 2300 RPM works.
    Pump shows the wattage at that speed is less than 800 vs 2000+ for the old pump!
    donaldm823's Avatar
    Cape Coral, FL
    147
    Yes there is a way to return to schedule after punching a different speed. I frequently hit the clean button which gives me 2x the scheduled speed. When I am done cleaning the pool, I simply select the speed number that corresponds to what the schedule would be and the pump program takes over
    Don SW Florida
    10,000 gal in ground concrete pool
    Pentair Cartridge filter, Pentair SWG, Pentair Intelliflow VS pump (11018)
    FAFCO solar panels w/Pentair SolarTouch controller
    using BBB for pool chemistry/Lamotte ColorQ tester for daily testing
    May 2011
    16
    Yes, you are right!
    Thanks for the info.
