Thread: Pool Kool deck stain
    May 2012
    Oconee, Georgia
    82
    I built my pool a month ago before I could get fence up red clay got tracked in on the Kool decking. How do I clean it off
    18'x36' inground vinyl liner.Pentair Sand Filter SD-60, Pentair EastTouch IC40 Salt Gen.
    Pentair Legend Cleaner. Pentair SuperFlo 1 hp pump. Color LED pool light.
    Taylor K-2006 (FAS-DPD) w/ SpeedStir. Pool Built October 2013.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Pool Kool deck stain
    Have you tried pressure washing, and scrubbing with the normal products like detergents and things? Sorry I'm not much help, but thought I would answer and maybe get some suggestions with a bump on your post. Here is a link showing what they recommend.
    Link Credit to duraleigh. (Thank you Dave)
    http://www.mortex.com/pdf/KoolDeck-CareCleaning.pdf
    Essential Links:
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Can you post a picture? Is it a thick coating of gook, or a red iron stain from the clay?
