Thread: switch - killeresse
    switch - killeresse
    has anyone tried to rigg a cutoff switch for the ozoneter? I really only want it to run when I am in for a long soak. Then turn it off shortly after I get out.
    48,000 litre (12680 gal); Hayward 24" Sand Filter; Zodiac/Clearwater LM3-24 SWG
    Inground Q-Quartz/Quartzon Plaster; 0.75HP Pump; 62 GPM filter
    Re: switch - killeresse
    can anyone chime in as to why this does NOT make sense? believe it would help lower chlorine demand when not in tub between soaks.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    I am guessing that no one has responded since, like me, they probably can't think of a down side. I do not have an ozonator on my tub so I can't look at something to see what would be involved, but it doesn't seem like it would take much. Seems like a good idea.
    bump. any help out there?
    22,553
    As Linen said, I can't think of a down side. I don't know how much power it draws or how they currently control it, but you may need a relay to control the power.
