- May 1, 2019
- 47
- Plaster
- CircuPool RJ-45
I turned on my pump the other day and a few sparks shot out so I turned it off. It had been raining recently and was wet in the area. That has never been an issue before, but wanted to mention it.
Left it alone for a couple days and tried it again today. First I opened the strainer and verified I could turn the impaler. When I turn on the pump, it makes a strange humming sound - it _does_ look like it is doing something to the water in the strainer, the square nut in the back does spin. But then it shut off after about 5 seconds.
I turned off the switch and opened the strainer. Tried filling it with hose water to see if it would overflow - maybe something is blocked - it usually doesn't fill - I'm guessing because the water just flows into the pool. It wasn't filling, so I opened the air release valve on top of filter. The strainer on pump filled with water right away, then it got really cloudy - I'm guessing its the DE that I had recently put in after cleaning my filter. I'm not sure if thats a "problem", or expected behavior.
Any ideas of things to check for the pump? I checked the power at the pump timer switch - verified 120V on each of the lines.
Removed the back plastic cover and took this photo:
Its a Waterways CHAMP-115
