Thread: Pool closing..Tulsa Okla
    Anyone in in Tulsa or a similar climate have advice on closing? I dont have a compressor to blow out the lines.
    Oklahoma
    30X20 Gunite pool completed in July 2013
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Pool closing..Tulsa Okla
    I would check out this article: Closing an In-ground Pool
    Quote Originally Posted by thelorib
    You can also use a shop-vac with a reversing feature that allows you to use it as a blower. If you have a leaf blower, you could try that as well.
    We do have a leaf blower...maybe that will work, thanks.
    Oklahoma
