Thread: mark all forums read not working
    Round Rock, TX
    529
    When I click the mark all forums read on the main index page it does not marke everything read.
    This used to work.
    thanks,
    dave
    15,500 gal, inground gunite pool with 7 ft spa, 2 speed pump 2hp/.33hp, 3/4 hp booster pump, Intermatic P1353 timer, AutoPilot SC-48, Sand filter with ZeoBest, Heater, that I never use . . .
    It worked for me... are you allowing the index to come back on its own, or are you clicking to return to the index? When I let it come back on its own, it did just fine.
    ETA I just checked, and it marks things even with clicking to return.
    Someone will be along to help shortly...
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
    Round Rock, TX
    529
    Something must have been screwed up with my account.
    I logged out to see if that would fix the issue, and could not re-log back in.
    I had to re-activate my account, close the web browser completely in order to log back in.
    Sheesh see if I ever complain again
    divnkd101's Avatar
    Mar 2007
    Pearland, TX (Houston Suburb)
    587
    LHDTV,
    I just ran into your situation.... However, come to realize that I had opened a thread inside a thread and tried to continue reading new post but they would not switch to read. Thought I would add that bit of info just in case someone else experiences that same problem.
    MIKE
    21K Inground Custom w/ Spa (Gunite/Plaster), SWCG, Hayward Northstar, Polaris 280, Hayward Color Logics, Jandy PS-8
